- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK53 v1 with firmware 2.7.2.102?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi there,
Does anyone know if the latest RBK53 firmware version 2.7.2.102 works with the RBK53 version 1 system (USB connector on back)? Netgear Orbi app only suggests 2.6.1.40 as available update.
Thx much in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK53 v1 with firmware 2.7.2.102?
@comainusa wrote:Does anyone know if the latest RBK53 firmware version 2.7.2.102 works with the RBK53 version 1 system (USB connector on back)? N
Yes, it does. I have it on two.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, CrimpOn - good to know. Did you expirience any kind of issues when switching to this firmware version? I'm trying to update my firmware (currently still on 2.5.1.16) due to issues with not showing all connected devices
and random disconnects of one of the two satellites.
Thanks much in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@comainusa wrote:Thanks, CrimpOn - good to know. Did you expirience any kind of issues when switching to this firmware version? I'm trying to update my firmware (currently still on 2.5.1.16) due to issues with not showing all connected devices
No issues so far, but it is "early days". I came directly from 2.5.1.16 (it's long and embarrasing story). So far, nothing stands out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can be manually downloaded and manually installed which is preferred:
Update the RBS first before the RBR.
@comainusa wrote:Hi there,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, I realized today that 2.7.2.102 has managed to "not show" two devices (1) a wired printer, and (2) a WiFi Echo Dot. The Orbi log clearly shows both devices receiving IP assignments via DHCP as they should. And, both devices function normally. No clue why 2.7.2.102 would think they are "Allowed devices that are not currently connected to the network." The Orbi "app" also does not show these devices as connected.
Now I share your delimma. Orbi firmware is not showing all devices. Do I (a) go back to 2.5.1.16 or (b) remain on 2.7.2.102 and try to remember that Attached Devices is incorrect, of (c) split the difference and try 2.5.2.4?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the update ... well, not showing only two devices is already pretty good, lol ... out of the approx. 40 connected things in our home, our Orbi (2.5.1.16) decided to only show about 12 of them as connected. Everything else is listed under "currently not connected to the network" although the devices are all working. I really can't believe that as a networking company they haven't manage to fix such a simple problem like this? This system is in the market now since 2019 I believe. Really sucks! Was hoping that the latest firmware update fixes these glitches, but looks like it doesn't. There is no point in buying a 2 satellite system when one of them just always disconnects itself after a couple of days, then needs to be re-synced.
Starting to consider to just dump this piece of crap and buy something else that actually works. I really do not have time to baby-sit a WiFi system that should be set and forget.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like you might have a faulty system if your RBS are disconnecting randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Swap the RBS around to see if the problem follows. If it does, one if your RBS maybe faulty...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks much. Yeah, sounds like that system must have some sort of fault ... great that it is now also out of warranty 😞
Sorry, but am quite frustrated at the moment ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
What channels are you using?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried to do a factory reset after the FW update? I had some devices not showing up either. Then after the factory reset...and a few reboots of the router, all 57 devices are showing up now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only after setting up the system for the first time, everything worked as it should for a short period of time, then things started to fall apart and never recovered. Besides the mentioned issues, the system also does not execute the entered IP address reservations, for example.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are the RBS directly wired to the back of the RBR or is there a LAN switch in between.
Try swapping RBS with each other to see if the problem follows.
@comainusa wrote:
2400sqf. Distance to satellite 1 is about 25 ft and about 30 ft to satellite 2 ( the one frequently disconnecting. Backhaul to both satellites is via ethernet (hard wired). Channel selection is on „auto”
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is a Gig-E switch (24-port Cisco Catalyst 3560G) between the Orbi Router and Satellite 1, plus one additional Gig-E switch (5-port AirLink)) on top of the Cisco switch between router and Satellite 2 (the one that is disconnecting).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Should I try to set up the system with WiFi back-haul instead of hard-wired?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would test the RBS wirelessly, then connect the RBS to the RBR using a different switch or if you can directly to the RBR with out the switch in between. Your swich is managed thus can cause problems.
Known working switches with orbi:
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work for Orbi systems.
Also it's best to keep with one brand of switch throughout the network system as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, thx. Will try what you suggest coming weekend. Will try to use my old Netgear 24-port Gig-E unmanaged switch for the connection to both satellites instead of the Cisco Catalyst and see if that solves the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It should. I'm currently using NG GS 1x series switches for my Orbi system. No problems here.
Keep us posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, what do you recommend regarding firmware? Stay with the current 2.5.1.16, update to 2.6.1.40 as suggested by Orbi management app or manually update to the lastes 2.7.2.102?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep v16, it was a solid version of FW. I found issues with v40. v102 seems pretty good and solid, though if you do, you will see this issue of an ARP storm happening after connecting the RBS via ethernet however it goes away given a couple of minutes:
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Keep v16, it was a solid version of FW. I found issues with v40. v102 seems pretty good and solid, though if you do, you will see this issue of an ARP storm happening after connecting the RBS via ethernet however it goes away given a couple of minutes:
Ok, thanks.
