- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK53 won't connect to internet (worked for the last year)
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBK53 wired to a vodafone router.
vodafone WIFI works fine
for the last year, the ORBI WIFIalso worked fine. yesterday it stopped connecting to the internet.
symtoms : no internet connection on Orbi WIFI, Orbi app on phone status is 'offline'. After a router reset, this appears as 'online' for about 5 seconds then goes to offline.
I have tried
- reset of vodafone and orbi routers, separately, and at the same time
- different cable between the two
- Orbi router firmware update
- Orbi router factory reset (give internet connect error during setup)
Hardware version : RBR50
Please help, dead in the water here.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK53 won't connect to internet (worked for the last year)
(also tried checking and unchecking the Traffic Meter, to no avail)
- Mark as New
- Bookmark
- Subscribe
- Permalink
(also tried switching to AP mode, no difference)
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here? If so, Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Was wondering about the ISP. Glad something was fixed.
Enjoy.
