Orbi WiFi 7 RBE973
Reply
RBK752 Orbi Router & Satellite Install
bobpak
Can the subject Orbi pair be installed via a wired connection between the gigabit ethernet ports on each or only via wifi connectivity between each of them?
Message 1 of 4
CrimpOn
Guru
Re: RBK752 Orbi Router & Satellite Install
It appears that the answer is "Yes", provided that certain gigabit switches are not between the router and satellite.
You might want to look at the community forum for the AX product line and search for "ethernet backhaul".
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Message 2 of 4
Mstrbig
Master
I have the RBK753 system and both satellites are wired through a NETGEAR 16-Port Gigabit Ethernet Unmanaged Switch (GS316). You can also wire them direct, router to satellites.
Message 3 of 4
Guru
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 617 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
