回复
RBK762 2.4GHz mode only 286.8mbps speed ?
ethanchueh
just upgrade RBK50 to RBK762 and found out the 2.4GHz mode shows max speed is 286.8Mbps, which is not expected speed(600Mbps) as RBK760 SPEC shows. btw, i've try turn off the 20/40 coexistence, seems no help, still shows 286.8Mbps.
the 5GHz mode show perfect 2401Mbps, which is exact same as SPEC shows.
what should i do to make 24.GHz mode shows max speed 600Mbps ?
1 条消息(共 1 条)
讨论统计
  • 0 条回复
  • 752 次查看
  • 0 个奖励
  • 1 交谈中
