- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK853 wifi 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, can any one tell me as I am planning to buy MESH WIFI and after checking reviews I found that ORBI MESH with 1 base and 2 satallite (RBK853) is better option for large house. Just wanted to make sure before spending $, will my old devices i.e iphone, samsung note 3 and 2015 MAC book pro having 802.11 n and 802.11ac connect to RBK853 (Wifi 6).
The reason i am buying RBK853 is gradually all the wifi 5 devices will be phase off as future is wifi 6.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, every device you now have will connect to the new Orbi WiFi 6. As far as they are concerned, it will not perform any better than the current WiFi 5 Orbi line. At some point in the next few years, there will be new devices which benefit from WiFi 6, most likely mobile phones, tables, and laptops.
WiFi 5 devices will not "phase off". They will continue to work indefinitely. Suppose there is a "new" garage door controller that somehow supports WiFi 6. Would you throw out the existing garage door controller that works every time? I have an Oster blender that is 50 years old. It still blends. I use it every day.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK853 wifi 6
Thank you. So I think at this point in time it is useless to invest in wifi 6 rather than I go for Orb RBK53 which I think is decent product. I have 100 MBPS up/down link, so I guess it will work fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK853 wifi 6
Be sure to post about any Orbi AX items over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
