Orbi WiFi 7 RBE973
Reply
RBR 20 and 2 Satellites - Firmware Version 2.3.5.36 - Hot Fix
jkirkg
Has anyone experienced any issues with thi update from .26 to .36?
I am experinecing extremely slow download speeds and I am curious if this frimware update will help that. It seems that classicly the firmware updates are troublesome and I am trying to research as best I can.
In cases someone is wondering, I have a COx Gigabit modem that is in Bridge mode before the Orbi system.
Thanks in advance!
Model: RBR20|Orbi AC2200 Tri-band WiFi Router, RBW30|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 4
Guru
Re: RBR 20 and 2 Satellites - Firmware Version 2.3.5.36 - Hot Fix
Before you update,
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 4
jkirkg
Cox Gigablast Modem - DTC4141
Running in Bridge Mode
Orbi is in router mode
What is the size of your home? Sq Ft? 2100 SF
What is the distance between the router and satellite(s)? 25-30 feet
What channels are you using? Auto? Auto
Any Wifi Neighbors near by? If so, how many? at least 6 networks close enough to access
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.- None of these arre running
Has a factory reset and setup from scratch been performed since last FW update? Setup from scratch has not been run
Message 3 of 4
Guru
You can keep the system running as is if the system is working well for you. Or you can choose to manually download the FW files for the RBS and RBR and apply them. If you do, update the RBS first, then the RBR lastly. After updating, Power OFF the RBS and RBR for 1 minute then back on. Check to see if the system is working well, if so, be sure to do a backup configuration to file for safe keeping. If you find the system isn't working well, factory reset the system and setup from scratch.
Keep the distance to 30 feet minimum. Any closer can cause problems.
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 593 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
