- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
RBR 40 needs reset every morning
My Orbi has been working great for the past 2 years until 4 days ago. With no changes to our router or gateway, my WiFi drops every morning when I wake up. Both my default and guest network is showing but internet is down. When I connect from the Orbi App remotely, it shows my device is disconnected. I’ll have to do a hard reset for it to function again. I’ve even factory reset yesterday and it’s doing the same thing again this morning. Anyone have any insight or ideal why this is happening?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBR 40 needs reset every morning
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
v16 working:
https://community.netgear.com/t5/Orbi/Orbi-SOAP-and-Excel/m-p/1901857/highlight/false#M90178
https://community.netgear.com/t5/Orbi/RBR20-RBS20-2-5-1-16-firmware-observations/m-p/1897766/highlig...
Has a factory reset and setup from scratch been performed since last update?
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@yhn280 wrote:My Orbi has been working great for the past 2 years until 4 days ago. With no changes to our router or gateway, my WiFi drops every morning when I wake up. Both my default and guest network is showing but internet is down. When I connect from the Orbi App remotely, it shows my device is disconnected. I’ll have to do a hard reset for it to function again. I’ve even factory reset yesterday and it’s doing the same thing again this morning. Anyone have any insight or ideal why this is happening?
Does the Orbi log show anything happening at those times?
The Orbi log is available only through the web interface (http://orbilogin.net), on the Advanced Tab, Administration, Logs. You would need to look at the log before rebooting the Orbi, because the process of rebooting erases the log file.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
It just went down mid-day.
I can't access orbilogin or default gateway address and get to the log. Just tried to connect thru LAN with no luck either.
Any other ideas? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@yhn280 wrote:I can't access orbilogin or default gateway address and get to the log. Just tried to connect thru LAN with no luck either.
It would be helpful to understand what prevented access from the LAN.
Is it correct to assume this was using a computer connected to the Orbi LAN ethernet port?
Did the Orbi web server not respond, or was there a problem logging into the Orbi using the web administrator credentials?
(user ID is always "admin" and the password was "password" when the Orbi was brand new, and the user was prompted to change it to something more difficult to figure out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Maybe give some feed back on the question presented to you as well might be helpful.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What ISP modem is your Orbi connected to? When you say disconnected, do you mean no internet access?
Could very well be the ISP modem is failing, causing the Orbi to disconnect.
If you are using a standard ISP modem, that has no setup features, perform a reset. Then to be safe, reset your Orbi and re-configure.
Check the power supply, to rule it out. It may not be putting out the proper voltage and/or amps.
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
There's always a logical answer, if you have all the facts!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I finally got into the log and it looks like it's a DoS attack from multiple IP locations?
[DoS Attack: ACK Scan] from source: 216.220.52.141, port 8190, Sunday, August 02, 2020 17:26:46
[admin login] from source 10.0.0.20, Sunday, August 02, 2020 17:25:12
[DoS Attack: ACK Scan] from source: 216.220.52.141, port 8190, Sunday, August 02, 2020 17:23:46
[DoS Attack: ACK Scan] from source: 205.234.175.175, port 443, Sunday, August 02, 2020 17:21:18
[DoS Attack: ACK Scan] from source: 216.220.52.141, port 8190, Sunday, August 02, 2020 17:20:42
[DoS Attack: ACK Scan] from source: 216.220.52.141, port 8190, Sunday, August 02, 2020 17:20:12
[Time synchronized with NTP server] Sunday, August 02, 2020 17:20:11
[Initialized, firmware version: V2.5.1.16] Sunday, August 02, 2020 17:19:27
Is that the reason why my wifi stop working? What should I do next?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
My ISP is AT&T with the Pace 5268AC gateway. Just redistributed my power supply that's got all the gadgets connected to. ISP modem could be failing but I literally just got this 3 months ago from my fiber internet upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
There's also something weird I just noticed. I was streaming from my laptop when the internet went down earlier. All the devices failed to connect to internet while my laptop continue on with the connnection. My laptop ended up being the only device that's still working until I did a hard reset. Any idea or insight into why/how this is happening? Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/tr...
@yhn280 wrote:My ISP is AT&T with the Pace 5268AC gateway. Just redistributed my power supply that's got all the gadgets connected to. ISP modem could be failing but I literally just got this 3 months ago from my fiber internet upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If it helps mine just started dong this last week. We have to turn it off and then back on to get it to reset. There have been changes to my computer or Spectrum modem. Seems like a Orbi issue to me.
Keith
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Do both wired and wireless connections stop working?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
@KeithBeeb wrote:If it helps mine just started dong this last week. We have to turn it off and then back on to get it to reset. There have been changes to my computer or Spectrum modem. Seems like a Orbi issue to me.
Keith
