Orbi WiFi 7 RBE973
Reply
RBR 40 - turn off Scheduled Internet
Revdacjr
I need help turning off a scheduled internet blackout.
I set a schedule to turn off the internet to test it. The router updated the firmware, and now I can’t turn the schedule off.
There is no option in the latest firmware update to turn the schedule off/on but the router still follows the schedule.
I’ve tried to revert back to the previous firmware to turn off the schedule but the router automatically updated to the latest firmware version.
Message 1 of 7
Guru
Re: RBR 40 - turn off Scheduled Internet
What browser are you using? Does this happen with IE11, Firefox or Opera?
Factory reset the RBR and setup from scratch. This time don't enable any internet schedule.
I would make a back up configuration to file. Then if you need to set the schedule again and need to revert back, apply the saved backup configuration from file which doesnt' include the internet block schedule.
Message 2 of 7
CrimpOn
Guru
Do you remember the version of firmware that allowed setting an "internet blackout"?
(and where on the web menu this feature was found?)
Thanks
Message 3 of 7
Revdacjr
I am using Google Chrome. I will try to reset to factory. Thank you.
Message 4 of 7
Revdacjr
Unfortuately, no. I dont remember the firware version.
Message 5 of 7
Guru
Let us know how it goes...
Message 6 of 7
Revdacjr
It did not work. The router auto updated to the latest firmware.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 702 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
