Orbi WiFi 7 RBE973
Reply
RBR 50 NOT working after Factory reset
venkyv
Follower
After Factory reset, Unable to see the 'Orbi' network to connect. Please help with steps for any Firmware Upgrade
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
CrimpOn
Guru
Re: RBR 50 NOT working after Factory reset
Firmware upgrade assumes the Orbi is working.  If these steps are followed, the Orbi should be broadcasting the WiFi name printed on the bottom label, usually ORBIxx.  https://www.youtube.com/watch?v=cMw4ePACgc4 Sometimes, people do not hold the paperclip in long enough for the Power LED to begin flashing amber.
Is there a computer (PC, Mac, laptop) that can be connected to the Orbi with an ethernet cable?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 314 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
