- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR / RBS 20 dropping internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m running the latest firmware V2.6.2.104. I looked at past posts and wasn’t able to get anywhere.
Any help would be appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR / RBS 20 dropping internet
I've beed struggling with the same issue since about the same time.
Model Name | Device Name | Status | ||
Router | RBR20 | V2.6.2.104 | No new firmware version available. | |
Satellite | RBS20 | V2.6.2.104 | No new firmware version available. | |
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ISP modem HW is
eMTA & DOCSIS Software Version:7.2.4.0.152
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
@Holylifton wrote:ISP modem HW is
Model:TG3482GVendor:ARRIS Group, Inc.SW version is
- Mark as New
- Bookmark
- Subscribe
- Permalink
The ISP modem is already in bridge mode. Worked witht eh ISP this past weekend and they see no signal drops from the modem so it appears the issue is with the Orbo router. They're sending me a boposter. I set the modem to gateway and turn off the orbi router and satelites. We'll see if the problem goes away.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Important to note that I had a dependable internet connection for years with this configuration. It just started happening the past few months. I did update the FWon tyhe orbi mesh to V2.6.2.104 and I'm wondering if that has anything to do with it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try the RBR in AP aswell:
ne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
Did you enable Armor or Circle on the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both armor and circle are enable. No factory reset performed after the last patch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lets factory reset and setup from scratch. Do not enable Armor or Circle this time.
Save off a new backup configuration to file for safe keep.
Test to see if the system continues to drop internet...Let us know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a factory reset yesterday morning. So far no internet dropping.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Make sure you do a backup configuration to file.
After that, you can start enabling Armor and or Circle. We've seen problems with these enabled before. Why I had you reset from scratch and not enable them. If basic configuration works and you save off a configuration to file. You can always go back to this if after enabling Armor and or Circle and you encounter problems again.
