Orbi WiFi 7 RBE973
Reply
RBR/RBS10 Mesh wifi
RobAllen
RBR/RBS10 Mesh wifi
Hello all. I have an Orbi mesh wifi setup. Comprising RBR10 and 2 RBS10 satellites. My question is regarding dhcp. If I disable dhcp on the RBR10 does the mesh system then just act as wifi repeater/signal booster and leave dhcp the my ISPS router?
Thanks in advance
Rob
Message 1 of 7
Accepted Solutions
Guru
Re: RBR/RBS10 Mesh wifi
Message 4 of 7
All Replies
Guru
Yes. There should be a AP mode setting though under Advanced Tab/Advanced Settings for that.
Message 2 of 7
RobAllen
So I need to disable router mode and select AP instead so it just emulates the existing wifi correct?
Message 3 of 7
Guru
Correct.
Message 4 of 7
CrimpOn
Guru
My Orbi has a check box on the Advanced Tab->Setup->LAN Setup page:
"Use router as DHCP server" (see attached image).
I had thought that this  means what it says and the Orbi can stay in router mode but not be a DHCP server.
I cannot test this because my modem is "only a modem" and if I turn off DHCP then I will have no DHCP.
Message 5 of 7
RobAllen
I have cable Router with built in dhcp so dont therefore need the Orbi used as dhcp but as good access point.
Message 6 of 7
CrimpOn
Guru
The discussion has wandered from the original question, "can the Orbi DHCP server be turned off" to a different topic:
"Is it a good idea to have the Orbi as a router connected to another router?"  Thousands of Orbi owners do this and experience no problems.  (They just unbox the Orbi, plug it in, start using it, and are happy.)
However, this is technically a "Double NAT" condition, which can seriously impede specific network applications, such as VPN, opening port to expose servers to the internet, and some internet gaming.  A Google search will turn up many explanations, such as the one from Netgear: https://kb.netgear.com/30186/What-is-Double-NAT
Putting the Orbi into Access Point (AP) mode is one solution that is often suggested. That has a side-effect of eliminating a host of Orbi features: https://kb.netgear.com/000061277/Disabled-Features-on-the-Orbi-when-set-to-AP-Mode  If you want to use Armor or Circle, then the Orbi has to stay a router.
There is no "right answer", as long as you are aware of the situation.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 999 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
