- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 1 of 3 Nest cameras wont show or record video after power cut
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I have an RBR20 with 2 satellites. I have 3 nest cameras. After initial set up, they all worked fine, this conitinued for about 4 months. I had to cut power for electrical work, since the power cut,1 of the cameras will not connect. It usually connects to a satellite. I have tried connected to the router and changing wireless settings a variety of ways, nothing works. I have also factory reset the camera a several times. No dice. I can connect to the wifi no problem but it wont show a live feed. I cant move the camera as the cable is fed through the wall and the wall has been sealed. I am based in the UK. Any advice would be greatly appreciated. Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 1 of 3 Nest cameras wont show or record video after power cut
Possible that the 1 camera is faulty if the other 2 cameras are working. Check with the Cameras Mfr for additional help and information.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly the camera is faulty. To help verify this, swap its location with one of your working cameras to determine if it is a location WiFi issue, or if the problem follows the camera.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it turns out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you try connecting the camera to a WiFi hotspot from your phone? If so that would help you determine if the problem is in the camera or the Orbi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since the user has the same model cameras and they connect to the Orbi fine, I presume that the one camera in question would be the problem and not the Orbi. However good idea to try a different wifi signal though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion, unfortunately it wont connect to my hotspot, not sure if it has to connect to a wifi as opposed to hotspot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
WiFi shouldbe WiFi as long as the hotspot is using the correct band for the camera (5Ghz I think).
It is looking like it is the camera. At least if Google/Nest says it is the WiFi you can tell them you tried connecting to a different WiFi and that also did not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ah maybe I didnt understand fully (im not the most knowledgeable on this). I tried to use a hotspot from my phone, which didnt work. The nests only work off 2.4Ghz in the UK and I dont know how to change the wifi. I will hopefully wrangle a new camera from them. Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your other cameras are working and the one isn't, either with Orbi or your Hotspot, then it's the one camera. Hope they can replace it for you.
@migstermav wrote:Ah maybe I didnt understand fully (im not the most knowledgeable on this). I tried to use a hotspot from my phone, which didnt work. The nests only work off 2.4Ghz in the UK and I dont know how to change the wifi. I will hopefully wrangle a new camera from them. Cheers
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks,can I just check that we are both talking about a hotspot from my phone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep.
- Mark as New
- Bookmark
- Subscribe
- Permalink
cool, thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good Luck.
