- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 2.3.5.26 Homekit not responding
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Everyone,
Per the title you can kind of see ehat my problems are. I currently have 2 Apple TVs set up and I can get them to connect to the Homekit network, but whenever I try to set them to do some sort of automation, they go into the Not Responding status.
Is there a port that I need to open on the router to enable the Homekit to work? I want to get this ironed out before I start diving into more smart home products.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 2.3.5.26 Homekit not responding
I think this is an iOS issue that has been around for some time now. Have you done enough troubleshooting to locate where the problem is?
But first, are you sure that your Apple TV, is connected to a hub? Please go to Settings > Accounts > iCloud and make sure that your Apple TV shows HomeKit as Connected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I checked both Apple TV's say they are connected to "My Home". So maybe they are actually connected and able to work, but I'm just a moron and can't figure out the correct automation to be able to have them automatically turn on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok, so now if you use the Home app on your iPhone and long press on the Apple TV, do you get the play window?
What happens if you try to pause/play on the control panel?
