- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 Issues Connecting and previously only able to log into device remotely
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Setup
- RBR20 w/ 2 satellites
- Airport Time Capsule connected via ethernet and WiFi on
- Connecting 2 Apple TVs, 4 iPads, 2 iPhones, 2 Ring cameras
- I've owned this Orbi RBR20 since May 2019
Scenario
Ever since I purchased, I've not been able to log into my Orbi device cleanly... I constantly received messages there were issues connecting and I logged in 'remotely.' However, recently I was having connectivity issues and inherently decided to reset the device and in that process believe I discovered the root of my problem.
Solution
- Delete the App from my iPhone (which is how I was connecting)
- On my iPhone forget the 'ORBI45' WiFi connection
- Download Obri app again and reconnect
I also unplugged power to my AirPort Capsule during the reboot process just to avoid that causing any interferrence. After I was able to confirm logging into the Obri app a few times without issue, I plugged back in the AirPort Time Capsule.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 Issues Connecting and previously only able to log into device remotely
Turn OFF the Wifi radio on the Apple Time Capsule. It's not needed since you have wifi on Orbi running.
