- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 Magenta, Satelline good
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've reset/rebooted the router two times, still magenta - the app shows that it's disconnected/offline....however the satellite is fine.
Do I give up and buy something new? Firmware Version V2.5.1.16 no updated required....? we purchased 1 1/2 years ago
any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 Magenta, Satelline good
@LLWLLL wrote:I've reset/rebooted the router two times, still magenta - the app shows that it's disconnected/offline....however the satellite is fine.
any suggestions?
what color is the ring on the sats. sats shouldn't be working IF the router is dead.
have you checked your modem?
don't use the app for troubleshooting...best to login in to the orbi using a web browser.
- Mark as New
- Bookmark
- Subscribe
- Permalink
modem is fine - ethernet cable is working
- Mark as New
- Bookmark
- Subscribe
- Permalink
satellite works not magenta nor amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
internet "offline" on main orbi, satellite showing active and have "wireless" signal on phone & ipad, but can connect to internet... work computer connected to modem I have internet.... changed the yellow internet cord with a new cord, no change, still no internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
internet "offline" on main orbi, satellite showing active and have "wireless" signal on phone & ipad, but CANNOT connect to internet... work computer connected DIRECTLY to modem WITH ETHERNET CORD - I have internet.... changed the yellow internet cord with a new cord, no change, still no wireless internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
and your modem? what type? any changes?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@LLWLLL wrote:internet "offline" on main orbi, satellite showing active and have "wireless" signal on phone & ipad, but CANNOT connect to internet... work computer connected DIRECTLY to modem WITH ETHERNET CORD - I have internet.... changed the yellow internet cord with a new cord, no change, still no wireless internet
WiFi signal on your wireless devices only means that they connect wirelessly to the modem or satellite, it does not mean you have internet. If your computer receives internet plugged directly into the modem then you have found your modem is working ok.
You connected the modem to the RBR20 and still get magenta...stupid question, forgive me - you plugged the cable from the modem into the yellow Internet jack, not the Ethernet jack, right? And you rebooted the RBR20 after that?
Did you try: 1) power down the RBR20, 2) power down the modem, 3) power up the modem, wait a couple mins, then 4) power up the RBR20...?
- Mark as New
- Bookmark
- Subscribe
- Permalink
any suggestions?
As @vajim pointed out, the "app" is almost useless for diagnosing problems. I notice that the post did not start out with a description of "what is not working." There have been many posts about the "app" saying the router was magenta, but that "everything works fine."
I am guessing that you looked at the app because "something was amiss"???
