- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 Satellite when enbled causes intermittent internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
when the satellite of RBR20 is switched on, there will be frequent disruption of interrupt connection.
When its left switched off, and have only the main router, then there will be no intermittednt issues in internet connection.
The satellite is connected to a server on ethernet cable. Thats the only wired connection on satellite.
Following the advices on community tried updateing to altest firmware. but no luck.
Any advices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 Satellite when enbled causes intermittent internet
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware Version: V2.5.1.16
AP mode is ON.
modem model:E31T2V1
Size of home: 3000 sqft
Distance between router:
Main rounter in 1st floor.
Satelite in 2nd floor at a vertical height of 10 ft and horizontal diatance of apx: 15-18 ft.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your modem model doesn't have a built in router or wifi. IF you have your Orbi in AP Mode, this needs to be changed to router mode as there needs to be a router in between the modem and your wifi devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router mode is set. My apologoes for not checking it throroughly
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Enabled Beam Forming. Did not enable MIMO
Dont know where to change these:
Restarted the both router and satellite.
The frequency of interruptions is not changed.
seeing these type of messages in logs which I dont know is the source for the interrptions?
[DoS Attack: SYN/ACK Scan] from source: 91.195.241.136
Note: For work, we connect to VPN .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Under Advanced Tab/Advanced Settings/IPv6
You can do a whois look up on that IP address...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even after these changes, seeing DOS attcks from some IPs which is causing the internet diconnections.
eg: [DoS Attack: ACK Scan] from source: 3.132.204.55, port 443, Tuesday, July 28, 2020 08:51:04
Dont know why this should dicconnect the internet connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The IP: 3.132.204.55 is from Amazon. I doubt that’s an actual attack. More likely just a false alert. I don’t know who the other IP address is but I’m not sure if it is an attack why it would only affect your satellite. I think that it is more likely something is up with your system. I see you have a RBR20 (which is a router) as well as an Orbi AC2200 (which is also a router). How have you got these configured?
- Mark as New
- Bookmark
- Subscribe
- Permalink
"I see you have a RBR20 (which is a router) as well as an Orbi AC2200 (which is also a router). How have you got these configured?"
Per my understanding, Have only RBR20 as router. Where is this Orbi AC2200 coming from. Where should I check for this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might have your ISP help you change the WAN IP address and check the ISP signal up to the modem to be sure that is working well.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Swap out the LAN cable between the modem and RBR. Use good quality CAT6 Lan cable.
I would factory reset the RBR and setup from scratch when the ISP helps you out with the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My bad. Im sorry. I saw this in your posting and misunderstood.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
A new observation :
If the satellite is switched off, with the same settings + Ofc laptop also ON, dont see any intermittent issues with internet.
The issue of intermittent internet is coming up only when satellite is enabled.
Hoping that the above information might help in suggesting steps to resolve the issue.
