- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 - Slow upload
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR20 - Slow upload
Hi,
It's been a while since I have this issue with my Orbi system. I looked for a solution but I couldn't find any.
I have my Orbi router connected directly to my home fiber and if I run a speedtest from Orbi's app speeds are fine. If I do it from any device upload is quite slow. Download is fine, it drops if I'm connected to a satellite instead of the router but that's not an issue I suppose.
For the upload it doesn't matter if I'm connected to the router or to a satellite, if I'm using wifi or ethernet or if I connect the Orbi to the ISP's router. It's always slow.
Sometimes restarting all the system fixes the problem for a while, like an hour or so, but then it comes back.
I also attached a speedtest to prove the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 - Slow upload
IF you see same issue while connected to the ISPs router with out the Orbi online, then you'll need to contact the ISP about this. This would be an ISP issue.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Please avoid posting any WAN IP address information in forums and pictures for security reasons.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for you answer. I'm on V2.3.5.36 and at the moment i don't have any ips router connected. The orbi router directly connects to the Nokia ONT I have. Using isp's router between ont and orbi doesn't solve the problem. I also tried using the orbi as access point to make sure that there is no double nat or stuff like that but it doesn't make a difference.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset and setup from scratch. Soon as the wizard completes, don't enable Armor, Access Controls, QoS speed test or Traffic Meter, just run the ookla speed test app from a wired PC.
Might update to v16 as last restort as well:
