- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 White light no connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve check with the network provider and they stated it’s up and running but it is not.
I’ve tired using the app to try and connect it properly and it won’t let me past as I have not internet connection.
Can anyone help ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 White light no connection
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would factory reset the RBR, press the reset button for 15 seconds then release. Power OFF the ISP modem for 30 seconds then back ON. Use a wired PC and walk thru the setup wizard with the RBR at orbilogin.com in a web browser.
