Orbi WiFi 7 RBE973
Reply
RBR20 and a satellite, won't connect to amazon or any other internet other than Netflix.
tim-c
I'm just having issues connecting to Amazon and everything else. Everything has been set up and Netflix works but nothing else.
Any thoughts or help would be appreciated.
Tim
Message 1 of 11
CrimpOn
Guru
Re: RBR20 and a satellite, won't connect to amazon or any other internet other than Netflix.
What device is attached to the Orbi network and cannot reach anything besides Netflix?
Message 2 of 11
Guru
Firmware on your orbi?
What modem/gateway is it connected to? (model)
Message 3 of 11
tim-c
Evening,
Thanks for the reply, the firmware on the Orbi is v2.3.5.30.
The router I'm running off of is an Action tech M1424.
Thank you,
Tim
Message 4 of 11
tim-c
My smart T.V.
Thank you,
Tim
Message 5 of 11
Guru
The actiontec is a modme/router combo device. do you have it in passthrough/modem only mode or the netgear in AP mode? otherwise you're in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
Message 6 of 11
Guru
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 7 of 11
Retired_Member
Not applicable
this qualifies as another..."how long have you had your Orbi?".....did you know you were going to have 2 routers??????
Message 8 of 11
tim-c
yes I knew that I would have two routers, I believe that the security is the issue. I have noticed only certain things I want to do including logging on to certain sights including amazon for movies and you tube it says it's not secure so it wont let me. Now I switch back to the old router for these scenarios until I find the security areas that will let me use these other sights.
Thank you,
Tim
Message 9 of 11
Retired_Member
Not applicable
OK...and you knew that this requires special configuration..??
Message 10 of 11
Guru
This maybe a browser issue or app issue vs a router issue. Security seen on sites are HTTPS. If a site isn't using HTTPS and uses HTTP, then browsers warn users of this. It's just a warning from the broswer.
Were you able to configure your networking so you only had one router on the line?
Thank you,
Tim
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 904 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
