- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 factory reset on reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RBR20 loses all settings on power loss or reboot.
I was making some updates to the router and hot apply .everything seemed to go through fine and I thought might as well reboot to be sure. After the reboot, all settings we're lost and I had to re-setup the ORBI system.
Even tested to see if I could reproduce, and sure enough, after a reboot, all settings we're gone again. Is this a memory issue or simply a bug?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
The v44 firmware seemed to fix it for me as well. Was able to get it uploaded and reconfigured with the new firmware and haven't had any issues since.
I will mark this as resolved since the new firmware was released.
Thanks everyone for helping troubleshoot.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 factory reset on reboot
There has been a bout of that happening with recent firmware on other Netgear devices.
I have no idea if this will work on an Orbi, but there has been some success with performing a "recovery reset" on other Netgear routers.
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
Strangely, after that the newest firmware does maintain settings on a reboot.
Of course, save your settings before you do this. Restore them after the reset and check that they stick after a reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the exact same issue. I've reporduced it a couple of times.
Reboot router - factory reset
Remove power - factory reset
Power off/on - factory reset
RBR20
Firmware V2.2.1.210
Modem CM1100
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried solution posted by michaelkenward but same result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the feedback.
Another possibility is to reflash the new firmware manually. Maybe it did not stick completely first time around.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'll give that a try as soon as I can. I've opened a case with Netgear support and will also post result.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try a full manual re-load of the FW files on the system using a web browser. Then do a factory reset and setup from scratch, walk thru the setup wizard using a web browser. Do a back up of the configuration to file.
Then test to see if the setting presist or if the system resets if powered off and back on or thru a reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mikevanocdn wrote:
Just bought my router system a week ago and having the exact same issue...if this doesn’t get fixed soon, I’m returning. My wife doesn’t know how to fix if I am not around and I am not going to waste my time whenever there is a power blip to fix this...life’s too short for this. Let me know if it gets fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So tried all the possible solutions in this thread so far to no avail.
Was previously on 2.1.3 (or something like that) and downloaded V2.3.0.28 and did a manual update through the GUI. On reboot, it went to factory settings.
Did the 30-30-30 power cycle, reconfigured everything, went to reboot, and lost all settings again.
I put a UPS on it for now just in case I have a small power outage, but still, incredibly frustrating to lose all settings on any sort of power loss or even software reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a manual download of the FW files and re-load the RBR again using a wired PC and IE11 or FF browser. After the FW is loaded, do one more factory reset and walk thru the setup wizard. Once setup. Back up the configruation to file.
Then test to see if the router retains the configuration by pulling the power. Back on.
IF the router doesn't retain the configuration, I would return the unit to place of purchase or ask NG for an RMA.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My system is now holding it's configuration.
After opening a case with Netgear they advised me that V2.2.1.210 was not the latest firmware even though the firmware update screen found no new firmware versions.
I downloaded V2.3.0.28 for both the router and satellite.
1. performed a complete 30-30-30 second reset (not sure this buys you anything but hey, took the advice and it's what i did.
2. Setup the router "Again"
3. Applied the RBS20-V2.3.0.28 firmware through the gui to the satellite
4. Applied the RBR20-V2.3.0.28 firmware throught the gui to the router
5. Setup the router "Again"
6. Performed a 30 second factory reset
7. Setup the router "Again"
8. Performed a reboot through the GUI - Success, config ok
9. Pulled the power - Success, config ok
If you have a complicated configuration I suggest performing a backup of your config.
I will follow up if I have any additional issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes after you update FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mikevanocdn wrote:
I’ll give this a try, but from what you said, looks like I don’t have the latest Firmware.
The Orbi's "find new firmware" feature is less than perfect. In other words, it often doesn't work. But it is easy enough to update firmware manually.
There is support for your RBK22, including firmware and manuals, at the end of this link:
>>> RBK22 | Product | Support | NETGEAR<<<
Firmware here:
RBR20 / RBS20 Firmware Version 2.3.0.28 | Answer | NETGEAR Support
along with instructions on where to shove it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if you need help getting Fw updated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mikevanocdn wrote:
Looks like the firmware update with 30-30-30 reset worked. Thanks all for the help. Hopefully this doesn’t become a trend.
Indeed. It may be no consolation, but past experience with other Netgear stuff suggests that this is a one off.
That "recovery reset" usually comes into play only when someone is trying to recover a "bricked" device that won't work at all.
With luck, the Orbi techies will have learned a lesson from this one.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad that fixed it. You should be ok now. Probably an odd ball issue with yoru system. Haven't seen anyone else post about this.
Please mark your thread as solves so if others do see this, they can try this.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
on V2.3.0.28 and had set it up a 4th time (no restore from backup, 30-30-30 reset, manual firmware upload). Seemed to work fine and past Sunday..boom..factory reset . So sick of this -
Just ordered a UPS for the main unit and maybe that'll help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would contact NG about this and ask for an RMA. This should not be happening at all, with or with out a UPS. You may have a bad unit that needs to be replaced.
https://www.netgear.com/mynetgear/registration/login.aspx
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't had a problem since updating to V2.3.0.28 followed by a factory reset. I've pulled the power once and rebooted twice without losing the config. I will run through the power and reboot tests again this weekend and follow up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
