- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 just randomly dropping connection!
- Mark as New
- Bookmark
- Subscribe
- Permalink
This mesh system has not been quite as reliable as I would have liked. Our RING doorbell downstairs is only about 15 feet away from the satellite router, but frequently tells me that the network signal is not strong enough for the live video signal to work. Our entire house is only about 1800 ft.², so this system should have been plenty strong enough for our needs. Our ISP download speeds from Spectrum clock in at over 200 Mbsp.
At this point, I am frustrated because Netgear will not give me any customer support without payment to even answer my questions, and I am looking at just returning the whole system to Costco for a full refund and buying a different router. I don’t like the idea of all that hassle, but we cannot keep doing this throughout the school year. We did not have problems over the summer with it dropping our signal like this so often. Does anybody have an idea of what’s going on? Do these devices just give out exactly one year after purchase? What other devices are more reliable? I don’t want to spend $400 on an oversized mesh system that is more than I need.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 just randomly dropping connection!
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have a Spectrum modem and router? How are you connected?
You said RBS20, that is 1 router. How many satellites do you have and how are they placed?
Taking it back and getting another manufacturer will not solve your problem.
Based on your size home, taking into consideration walls, wiring, appliance and electronics interference, WIFI band congestion, etc. you should have 1 router and 2 satellites, and place them far enough apart for coverage.
