Orbi WiFi 7 RBE973
Reply
RBR20 no sync satellite
Jenn1949
My RBR20 router will not sync with RBX33 plug in satellite
Tech support for over and hour
Please advise on if compatibility issue or bad satellite
Thank you for your help
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 9
Guru
Re: RBR20 no sync satellite
What FW version do you have on the RBR and the RBW? If you can access the RBWs web page. Possible that the RBWs FW is out of date or out of sync and needs to be updated? Did NG discuss this with you?
Message 2 of 9
Jenn1949
Thank you but you are dealing with a MeMe
What is FW?
And how do I go to a website?
Thank you
Also received offer to purchase Pro warranty but every time I click on it, I go to Netgear with no info on purchasing the warranty.
Do I need to call. Netgear as I only have one more day to accept this offer
Thank w
Message 3 of 9
Guru
FW=Firmware
Log into the RBRs web page with a PC or laptop wire or wireless connected to the RBR. Navigate to orbilogin.com or 192.168.1.1
Yes you'll need to contact NG support for warranty help.
@Blanca_O
Message 4 of 9
Jenn1949
Thank you
Have a joyous Christmas season with family and friends
Message 5 of 9
Jenn1949
Just read firmware
When I was on phone with technical help. And we were scrolling through advanced stated FW needed to be updated
Asked tech support but each one stated to not bother doing update
That maybe the issue
Message 6 of 9
Guru
Yes, the RBWs need to be on same verions of firmware or at least on version behind or ahead. NG needs to help you get the RBW updated. If the RBWs have a LAN port you can try this, download the lastest FW file from NG download site on to the wired PC.
Wire connec the PC to the RBW. Factory reset the RBW and give it 5 minutes. Open a web browser and navigate to 192.168.1.250. If you get to the RBWs web page, then log in with admin and PW is password. YOu can manually send the unpacked FW file to the RBW here.
If this can't be done, you'll need to contact NG support and have them help you with this.
@Blanca_O
Message 7 of 9
Jenn1949
Traveling
Thank you
Will do when I get home the first of January
Message 8 of 9
Guru
Smiley Wink
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1035 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
