Reply
Highlighted
Initiate
RBR20: periodic internet outages
We bought a 2-pack (RBR20 + RBS20) 2 months ago. Our connection speed is now exceptional connected to the fibre router. We really like the product. We moved to a new house four weeks ago and bought another RBS20.
But all this time our connection has dropped off once or twice a week. It's down for about 15 minutes. It never used to happen with our previous system (Airport Extreme).
Do you have any thoughts or simular expreiences?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Highlighted
Guru
Re: RBR20: periodic internet outages
I
My Setup (Cable 900Mbps/50Mbps)>CAX80(Modem Mode)>RBK853 v3.2.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 151 views
  • 1 kudo
  • 2 in conversation
Announcements
