- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 running firmware V2.5.1.16 doesn't get full GB fiber connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have an Orbi RBR20 and we just upgraded to 1gb Fiber. When I run a speedtest on a laptop (both wireless and wired through the Orbi router) I only get 120Mbps down. If I plug my laptop into the ethernet cable coming out of our wall, i get 976Mbps. I've done a full Factory Reset, disabled Daisy Chain Topology, Accesss Control, and Traffic Meter and still getting 120Mbps. Any other suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 running firmware V2.5.1.16 doesn't get full GB fiber connection
Is Armor or Circle enabled on the RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
the Orbi router plugs directly into the ethernet cable (cat5e) going to the Optical Network Terminal. Armor and Circle are not enabled on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When speed testing, using a wired PC and Ooklas installable speed test app on your wired PC, what are the speed results after doing a factory reset on the RBR and walking thru the setup wizard. Do not enable Armor or Circle. Power cycle the ONT off for 30 seconds then back on as well while the RBR resets.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can also try other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
