- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 - slow
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR20 - slow
I set this up as directed. From my cable modem/router I get speeds of 200-250 on the main level. Upstairs at the office I get 60-70. I connected the Orbi and I only get 20 upstairs. Basically, it is worse than the cable modem/router. Did I do something wrong or is my setup just better for the stand alone modem/router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 - slow
What is the Mfr and model# of the ISP modem the NG router is connected too? If this is a modem/router, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #3 first...
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
