Orbi WiFi 7 RBE973
Reply
RBR20, speeds like a repeater?
jbinbi58
Follower
Brand new RBR20 and satellite. Newest firmware. Just installed. Have xfinity, get around 300 down. The computer is in the same room that the xfinity modem is in, while attached to xfinity device via wifi, I get about 230ish down. When I change the wifi to attach to the RBR20, (not the satellite device) which is right next to the xfinity modem, right next to the computerI am getting at most about 90ish. I have no other devices attached. This seems too low.
I have not put the xfinity in bridge mode, so I have xfinity broadcasting it's wifi on separate SSID than orbi.
I know wifi repeaters can give you at most 50% of the total wifi, they need up and down, but I thought the mesh, since it is attached via enet would broadcast at same speeds as xfinity modem.
Message 1 of 2
Guru
Re: RBR20, speeds like a repeater?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. Also having other wifi signals in close proximity to the RBR is not recommended as well. Can cause problems.
https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 318 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
