- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20 with RBW30 WiFi Speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20 with RBW30 WiFi Speed
What WiFi devices are you using to speed test. Some WiFi devices maybe maxed out or limited by there design. Most current devices should see any where from 400-500Mpbs depending upong connection rate.
What connection rate is the wifi devices connected? Use WiFi Sweet Spots on your mobile device to see the connetion rate.
Ensure your device is connected to 5Ghz instead of 2.4Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
