- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR20
Will need more information here:
Is the Orbi system operating in Router or AP mode?
Modems with built in routers:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
