Orbi WiFi 7 RBE973
Reply
RBR20
d7424
Initiate
RBR20
ONE SATELLITE BACKHAUL STATUS IS GOOD OTHER ONE IS POOR. CAN I DO SOMETHING TO MAKE THE POOR ONE BETTER?
Message 1 of 4
Guru
Re: RBR20
With that limited info, maybe?
What size is your home?
What is the interior of your home made of? certain materials block wifi better than others.
Have you tried moving the satellite around? Sometimes obstructions in walls (think hvac) can block wireless signals. Moving it further away, closer, or even laterally can sometimes help.
How far from the router is the satellite?
Are you using daisy chaining? (where it goes router----->satellite---->satellite)
Message 2 of 4
d7424
Initiate
Re: RBR20
Thanks plemans, will try moving satellite first.
Message 3 of 4
Guru
Re: RBR20
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 351 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
