- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR40 Keeps Dropping Internet Connectivity
- Mark as New
- Bookmark
- Subscribe
- Permalink
So up until about 2 weeks ago or my ORBI RBR40 had been working perfectly. I also have the satellites, which I haven't really noticed the issue with yet, although I will say due to placement in my homes, the Satellites are covering the far corners of the house so I'm really not on them too much. Anyway, I'm not extremely tech savvy especially with Networking, but I'm running into an issue where the internet seems to keep dropping every 30 minutes or so, after 2-5 minutes it resolves itself, but I work from home and this has been a pretty big inconvenience because of its reoccurence. I have read through a few of the other posts to turn off Daisy Chaining, set the 2.4GHz to a manual channel. I also downloaded and manually loaded the Hotfix version that Netgear has posted, V2.3.5.34, was previously V2.3.5.30.
I'm happy to listen to ideas, I've had the system since December of 2018, and again now issues until now. Also a friendly reminder, I'm not super tech savvy but can navigate it through most things just please be thorough in any suggesstions.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
so V2.3.5.34 didn't fix your problem? I would go back to what you had.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR40 Keeps Dropping Internet Connectivity
I'm going to accept this as solution as now, I have decided to move on from Netgear, and I am getting rid of the system. Just going with what is provided by my ISP, since I have turned off the Orbi and turned on the Router portion of the modem they sent I've not had any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tSmith92 wrote:I'm going to accept this as solution as now, I have decided to move on from Netgear, and I am getting rid of the system. Just going with what is provided by my ISP, since I have turned off the Orbi and turned on the Router portion of the modem they sent I've not had any issues.
Hate to see you go....especailly since it worked before. Something changed in your system. The challenge is finding out what. But it's your system and life is to short to worry about things such as this. Good luck.
