- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR40 / RBW30
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR40 / RBW30
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR40 / RBW30
When the backhaul link between router and satellite is "good", it will achieve the highest transmission speed. "Fair" will be less than that. If the backhaul link is significantly greater than the internet rate, then you gain little be improving it. However, with so many people paying for higher internet speeds, a slow link between router and satellite will mean devices connected to the satellite have worse performance than devices connected to the router.
If you want to know what the backhaul link rate is, it takes some effort. (RANT: Netgear's Orbi "app" conveniently shows the "Link Rate" for devices except satellites, but the web interface uses only terms like "Good", "Fair", etc. and silly WiFi "bars.")
Go to the debug page (http://<ip of orbi>/debug.htm) and check "Enable Telnet". Then, get a telnet client (Windows has one that can be actiated from the "Programs" control panel. I use Putty because it makes keeping a log of the session easier.) Log into the Orbi using the admin ID "admin" and the administrative password, then type satelliteinfo wifi.
Here is what my RBR50-RBS50 link shows:
root@DickRBR50:/# satelliteinfo wifi
"mac address" : "A0:04:60:0D:96:FA",
"hop" : "1",
"bridge mac" : "A0:04:60:0D:96:FA",
"backhaul conntype" : "5GHz",
"backhaul rssi" : "-68",
"backhaul macaddress" : "A0:04:60:0D:96:FD",
"backhaul phytxrate" : "780",
"backhaul phyrxrate" : "780",
"backhaul parentmac" : "A0:04:60:1C:02:39"
Notice that my transmit and receive rate over the 5G backhaul link is 780mb/sec. That is significantly higher than my internet connection of 100mb/sec. So, even considering WiFi overhead, the router-satellite link is not a bottleneck.
