- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR40 Router when press sync button the white rings do not flash
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, trying to sync an add on RBS20 satelite. when i press the sync button the RBR40 router the white rings do not light up. any ideas how to get the router to start syncing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR40 Router when press sync button the white rings do not flash
@eclipse31satx wrote:Hi, trying to sync an add on RBS20 satelite. when i press the sync button the RBR40 router the white rings do not light up. any ideas how to get the router to start syncing?
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
thank you for your reply. i have seen these instructions and video. my problem is when i press the sync button on the RBR40 router the white ring does not light up and blink. how do i get it to do that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@eclipse31satx wrote:thank you for your reply. i have seen these instructions and video. my problem is when i press the sync button on the RBR40 router the white ring does not light up and blink. how do i get it to do that?
at this point I would login to the orbi login page using a pc and see if the sat shows up there.
otherwise perform a factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
looking back over the instructions...i don't see the word white
- Mark as New
- Bookmark
- Subscribe
- Permalink
yeah, youre right. it says the rings will light up. mine doesn't do that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@eclipse31satx wrote:yeah, youre right. it says the rings will light up. mine doesn't do that.
it says this..."
- Solid blue. If the LED is solid blue for 90-180 seconds, your router and satellite successfully synced.
all other colors is bad
The blue should eventually go away
If you still are concerned about a missing LED light on the sat I would check the login page then maybe a factory reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
here's something else that may help:
- Mark as New
- Bookmark
- Subscribe
- Permalink
thanks but my issue is the router, all the directions say its supposed to light up to sync, but it is not doing that. i press the sync button and i get no light to flash.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@eclipse31satx wrote:thanks but my issue is the router, all the directions say its supposed to light up to sync, but it is not doing that. i press the sync button and i get no light to flash.
So if you can't confirm that the sat is connected via the pc login I would do a factory reset
