Orbi WiFi 7 RBE973
Reply
RBR40 - Update Firmware Discrepency
TallTell
I have the RBR40 mesh with 2 Orbi Satelites.  I received an email on March 15, 2020 stating there is a new version of firmware out v2.3.5.34.  When I go to the router settings, it states my firmware version is v2.3.5.32.  When I go to 'Check for Updates' it states 'No new firmware is available at this time.'  I would assume .34 is the latest version.  Why am not able to update to .34 from .32?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 7
Accepted Solutions
Retired_Member
Not applicable
Re: RBR40 - Update Firmware Discrepency
@TallTell wrote:
I wanted to make sure I was up to date.  According to my app I am.  Thanks for you reply.
ok....in the future no need to worry or keep checking about firmware updates.
when there is a critical update, NG will push it to you automatcially.  no action required on your part.
Message 5 of 7
All Replies
CrimpOn
Guru
Damn Netgear and their emails. If your Orbi is working to suit you, I would well enough alone.
If you want to "roll the dice", navigate to http:netgear.com/support and enter the Orbi model number. The Downloads link will bring up all of the available firmware versions.
Good Luck
Message 2 of 7
Retired_Member
Not applicable
Aside from the fact that you received an email from NG, why do you want to upgrade your firmware??.
Message 3 of 7
TallTell
Message 4 of 7
Retired_Member
Not applicable
Message 5 of 7
Guru
You can check NGs download site for updates and release notes and manually download and apply FW files if you want to as well.
Good Luck.
Message 6 of 7
Retired_Member
Not applicable
or...they can just leave things alone....its too crowded living on the edge
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1063 views
  • 6 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
