Reply
RBR40 Will it work with DOCSIS 3.1
ctcowboy
Follower
I have the ORBI RBR40 wifi extender router and 2 satelittes. I also have Cox Cable Gigablast and want to upgrade the Cox modem to the netgear c7800 which will work with gigablast because it supports DOCSIS 3.1
My question is will the RBR40 throttle down the gigablast or will it work with DOCSIS 3.1?
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 2
Guru
Re: RBR40 Will it work with DOCSIS 3.1
It should see near 900Mb on a wired LAN cable connection with a PC. Factory reset the Orbi router and set up from scratch with the modem. Don't enable QoS, Traffic Meter or Access Controls on the Orbi router. Disable IPv6 if your ISP doesn't support it natively.
DOCSIS is a protocol of the modem and between the modem and ISP service, not a router.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1394 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
