Orbi WiFi 7 RBE973
Reply
RBR40 drops wifi says password incorrect
kyle59
Follower
We are having issues with our RBR40 with two satellites. About 5 months ago we began having devices kicked off of wifi and, when trying to reconnect, were told the password was incorrect.    Over the Thanksgiving weekend we set the router and two satellites back to factory default, then reset passwords, etc. The same thing  continues to happen.   Our firmware is V207.3.22   We are willing to replace the system if need be, but want to first make sure we've exhausted all possible fixes.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router, RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 3
Guru
Re: RBR40 drops wifi says password incorrect
Are you using any special characters in the SSID name or password?
Are you using a browser or Orbi app to set up the RBR after the factory reset?
Be sure RBS are fully synced correctly.
Be sure RBS FW is the same version as what the RBR uses.
Message 2 of 3
CrimpOn
Guru
Could you please clarify one detail: which password was said to be incorrect:
  • The WiFi password, or
  • The password to access the Orbi web browser administration, or.....?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 508 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
