Orbi WiFi 7 RBE973
Reply
RBR40 won’t reset, what would you replace it with?
ccoffee60
Orbi 42 purchased in 2018
RBR40 won't reset and probably dead.
For home use. 2000 square feet down and 2000 square feet up .
200 Mbps ISP speed
What would be a reasonable replacement in the Netgear family?
Would you get a modem/router combo?
I have ordered a refurbished replacement from Amazon and currently using a Netgear AC1750 loaner which is working very well
Message 1 of 4
Accepted Solutions
Guru
Re: RBR40 won’t reset, what would you replace it with?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 4 of 4
All Replies
Guru
How do you know its dead/won't reset? (Details are key as fixing it might be possible)
For the speeds you're paying for and size of your home, its a pretty spot on setup.
So a refurb/replacmenet of the RBR40 is a solid option.
Message 2 of 4
ccoffee60
i have tried all the reset options, including 30-30-30... nothing...
Now awaiting a refurbished RBR40 from amazon
Thank you for your thoughts and reply
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 702 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
