Orbi WiFi 7 RBE973
Reply
RBR40
mizeke
RBR40
I have an rbr40 with two satelite rbr30's..........I also have xfinity rented modem with voice(phone) service........Is there anything to buy from orbi that will replace xfinity modem and still have voice......Would love to drop the xfinity modem and lose the monthly rental fee.....but I don't want to lose existing phone service with existing number.
Message 1 of 8
Accepted Solutions
Guru
Re: RBR40
Xfinity supports BYOM and you can buy your own modem to use on there system. Find out what they support first before you buy.
I believe NG's CM1000/1100 series modems are supported on XF...
Message 4 of 8
All Replies
Guru
Re: RBR40
Netgear has multiple modems with voice options available. Not specifically an orbi device but a modem/voice device.
https://www.netgear.com/home/products/networking/cable-modems-routers/CM1150V.aspx
https://www.netgear.com/home/products/networking/cable-modems-routers/CM500V.aspx
These are just 2 from doing a quick search. A little time with google would show more.
Message 2 of 8
Guru
Re: RBR40
Please remember to post here in the main Orbi forum for your model Orbi:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
FYI, bad modems to avoid:
https://badmodems.com
Message 3 of 8
Guru
Re: RBR40
Message 4 of 8
CrimpOn
Guru
Re: RBR40
You are SO LUCKY.  My service is through Spectrum (previously Time Warner, now part of Charter).  The ONLY option Charter provides for voice service is an MTA that MUST be rented.  Ca-Ching. Every month, forever.
Message 5 of 8
mizeke
Re: RBR40
Thanks, I'll take a look.
Message 6 of 8
mizeke
Re: RBR40
Thanks, I'll take a look.......it looks like this will work.
Message 7 of 8
Guru
Re: RBR40
Enjoy. Smiley Wink
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 3083 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
