- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 2.3.0.32 Firmware upgrade file incorrect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Just downloaded RBS50-V2.3.0.32.img and RBR50-V2.3.0.32.img. The manual update of the Satellite worked fine. The RBR50 file however is not accepted by the router (This firmware file is incorrect! Please ...). Anybody else having this issue? What can I do? The automatic update says 2.2.1.212 is the most recent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 2.3.0.32 Firmware upgrade file incorrect?
OK, I found the solution. Before being able to upgrade the Orbi Router to 2.3.0.32 you have to install an intermediary update 2.2.1.212, this is only slightly higher that the latest release the router detects (2.2.1.210). After doing that it worked. The Satellite would upgrade directly however, without this intermediary step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you need to install v212 first on the RBR. You can update the RBS directly to v32 with out the v212. This is just for the RBR unit.
All files are here:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying to manually update my RBR50 and satellite. I tried automatic but it says I have the latest firmware, I'm running 210.
So downloaded the 212 and 32 firmwares from netgear. Tried to install 212 manually twice on satellite and it says file is not the correct one. Am I missing something? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
My stupidity... I was clicking the RBR file for RBS...Thanks for the reply.
All updated and good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
