Reply
RBR50 - Download is slower than Upload
Accutronman
Guide
Have ATT 1gb fiber with RBR50 in router mode connected to Pace modem set to DMZplus mode. Running the Internet speed test within the Orbi app, I’m getting average upload speed of 800-900mb but only an average download speed of 560-570mb.
Any suggestions on increasing download speed?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: RBR50 - Download is slower than Upload
Orbi app on a mobile device?
If so, then the orbi is working to spec...
What are your LAN cable connection with a PC speeds test at?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 3
gr8sho
Virtuoso
The 5268AC has had numerous issues with DMZ mode. I’m surprised you’re even getting those speeds TBH.
Orbi RBK50 in AP mode, 100/20 Mbps VDSL2, Arris BGW210 gateway
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1131 views
  • 0 kudos
  • 3 in conversation
Announcements
