- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Dropping Internet Connections with Firmware 2.5.1.16
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since I upgraded my firmware to my RBR50 to version 2.5.1.16, I am losing my Internet connection each day, once or twice, completely, and will drop intermittantly once or twice an hour all the time. Any others experiencing this? It was solid on the previous version. I have checked with my ISP, and no one else is experiencing this. When I drop the Internet completely, I reboot the router, and I'm back on.
Setup: RBR50 + satellites: RBS40 - RBS50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Dropping Internet Connections with Firmware 2.5.1.16
I
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Press the back reset button for 15 seconds then release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have given me the playbook on how to fix dropped connections and I appreciate it. However, my question is this, why would upgrading to firmware 2.5.1.16 be the start of these problems? Why wouldn't I have been dropping my Internet connection be a problem with the earlier firmware versions. I didn't make any configuration changes, only upgraded.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@DML1-1 wrote:You have given me the playbook on how to fix dropped connections and I appreciate it. However, my question is this, why would upgrading to firmware 2.5.1.16 be the start of these problems? Why wouldn't I have been dropping my Internet connection be a problem with the earlier firmware versions. I didn't make any configuration changes, only upgraded.
I had the same issues as you. Even a factory reset wasn't helpful. The last stable version for me is 2.3.5.30 and I wouldn't go any higher than that unless you like frustration.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sometimes new FW needs a reset as it bring in new items which maybe incompatible with older configurations. So a reset maybe needed as last resort if you encounter problems after a reset. it's a mixed bag on updates, some people don't see problems after a FW update, some do. Try a reset and setup from scratch. IF the problem continues, then you can revert back to what had worked for you. I for one have a well working RBK50 system on v16, however I always reset mine after a FW reset so I avoid most issues.
Also ISP service can also impact operation as well. May work for a time then doing something like a FW update may bring the problem to light which should be addressed. Reason why asking about your ISP services.
It's up to you if you want to give feedback to questions or not. Feedback helps us help you though.
Good Luck.
