- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Drops WiFi Roughly Every 6 Days
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
About every 6 days, my ORBI RBR50 WiFi stops. I have to reboot to get things going again. Anyone else having the same issue? Firmware version is V2.5.1.8
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Drops WiFi Roughly Every 6 Days
This isn't a FW issue. More like a interference issue or configuration issue.
Also there is newer v16 FW available as well to try...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@edthesprinter wrote:Hi,
here's your problem.........Firmware version is V2.5.1.8
get rid of it
