Orbi WiFi 7 RBE973
Reply
RBR50 Firmware Update
RDMSYS
Star
I have a notification for new firmware (V2.5.1.16). However when I do the check, the router firmware is found but my Satellite stays at Please Wait A minute for 5 minutes then fails. I would like to apply it but I'm not sure with this issue.
Anyone else see this?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 10
Accepted Solutions
Guru
Re: RBR50 Firmware Update
It usually should do everything, however maybe some times that doesn't work. So the alternative method of manually loading FW is available. Glad it worked for you. Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 10 of 10
All Replies
Guru
Message 2 of 10
RDMSYS
Star
Thanks but I would rather let it do it. I was thinking of doing it via the app. I'm still not sure that it would have issues or not.
Message 3 of 10
Guru
"let it do it" doesn't seem to be working. You can leave it as is but I wouldn't recommend updating via the app, especially if you're already having issues. Reason why is it tends to be the devices that were updated via the app or wireless that we tend to see corrupt firmware issues on.
But again, up to you.
Message 4 of 10
gr8sho
Virtuoso
Just did from iPhone and worked correctly.
Message 5 of 10
Guru
Try powering OFF then back ON, the RBS and RBR then use the RBRs web page again to check for the RBS update.
What version of FW is currently loaded?
Message 6 of 10
RDMSYS
Star
Current version is V2.5.1.8. I will give that a shot but cannot do it until after work with everyone here online.
Thanks!
Message 7 of 10
Guru
If all else falses you can manually download the RBS fw and upgrade the RBS 1st using it's web page, then go for updating the RBR lastly.
Message 8 of 10
RDMSYS
Star
OK, I did it via the web. First it did update the router. Then came back and the satellite worked. Never saw this before as usually it does both at same time.
Thanks all...
Message 9 of 10
Guru
Enjoy. Smiley Wink
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2025 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
