Orbi WiFi 7 RBE973
Reply
RBR50 - Getting randomly disconnecting Microsoft tools.
hugoravache
Hi Everyone!
I have RBR50 on V2.3.5.30 version and it is disconnecting my Microsoft Tools such as Skype and Teams.
It was not happening before I upgrade to the latest firmware version. This is happing on Windows 7 and Windows 10.
Should be something with ISP and tried to open a case with NETGEAR however my support already expired.
Does anyone is experince this situation and maybe know how to fix it?
Thank you!
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: RBR50 - Getting randomly disconnecting Microsoft tools.
I believe your ISP modem already had a built in router and wifi:
https://uk.humaxdigital.com/network/hgb10r-02/
If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 4 of 5
All Replies
Guru
Are you wired or wirelessly connected to Orbi with your PC?
Has a factory reset and setup from scratch been performed since last update?
Message 2 of 5
hugoravache
My ISP modem is Humax model HGB10R-02. I'm having this issue on cable or WiFi...I have tested both. No, just did a reset and configured it again. I'll monitor and check if the issue is resolved. One thing a noticed is my router was on V2.3.5.30 and my satellite was on V2.5.0.38. So I update and both are now on V2.5.0.38.
Message 3 of 5
Guru
Couple of options,
Message 4 of 5
hugoravache
The first option works for me. I configured my ISP as bridge mode and turn off the Wifi and configured Orbi as router mode using its WiFi.
Thanks a lot for the very details support! Really appreciate it!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1939 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
