- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 Lan Ports Not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 Lan Ports Not Working
Are ethernet cables in good condition and quality. Some cables could be a cause.
I would disconnect all devices then connect up one wired PC and let it run. Check the connection. Then enable one of the other devices. Check for the problem. Graduate adding devices.
Any chance you have a external Gb network LAN switch avail to test with? You could connect up all devices to it and see if router still fails.
If anything pops up, could be a device issue or router maybe faulty.
@Guapo_Apowrote:
Out of nowhere LAN ports on RBR50 have stopped working. WAN works great. Found this out as Smartthings hub went offline and Amazon video stopped playing. Will intermittently come back on of I reboot the router. Any ideas or is this hardware related?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue every day I have to reset my router once because LAN goes down sometimes WAN goes out too but everytime it starts with LAN
V2.1.2.18
Is there a Fix
Would like a router to act like a router kind of pointless if it cant connect things
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would need more info your experiences.
What is the Mfr and model of the ISP modem? built in router by chance?
Is the ethernet cabling between modem and router and devices of good quality? Cat6 recommended. Don't mix Cat# cables.
What ethernet devices are you connecting to the router?
Try the suggestions I mentioned to see any changes in behavior with the router. Graduate adding devices.
@Brain29wrote:I have the same issue every day I have to reset my router once because LAN goes down sometimes WAN goes out too but everytime it starts with LAN
V2.1.2.18
Is there a Fix
- Mark as New
- Bookmark
- Subscribe
- Permalink
modem is a Motorola SURFboard SB6141 dirrect into the orbi
right now I have cat 6a but I have 5a and 8a on hand not sure why copper thickness or mix would make a router crash ???
satallite is connected wireless
- Mark as New
- Bookmark
- Subscribe
- Permalink
everything connected to the router is the same that was connected to an old asus router that never dropped lan
- Mark as New
- Bookmark
- Subscribe
- Permalink
What ethernet devices are connected to the back of the router? Mfr and model#?
Theres cat6 and CAT6a. Cat6A is in wall big cable for in wall and ceiling runs.
Cat 6 is standard patch cables used between home and office devices.
Cat 7 is targested for over 10Gb network services.
Cat 8 is designed only for data centers where distances between switches and servers is short. It is not intended for general office cabling.
@Brain29wrote:modem is a Motorola SURFboard SB6141 dirrect into the orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
"not sure why copper thickness or mix would make a router crash"
RBK50-100NAS
RBS50
samsung smarttv
harmoney hub
vontage phone servcie
3 workstations
2 raid servers (typically in idle)
wireless probally 8 phone and tablets (maybe 2 in use at one time)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cables could be bad or not of good quality.
Which devices do you have connected via ethernet cable with the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
ethernet devices
(unmanaged swtich) samsung smarttv
(unmanaged swtich) harmoney hub
(unmanaged switch) vontage phone servcie
(2 direct 1 switch) 3 workstations
(1 direct 1 switch) 2 raid servers (typically in idle)
there are no bad cables the switch goes down with everything else
There is power to all the lan ports but the orbi dose not deliever IP address or subnet
I can connect to the router via wireless most the time 2 out of 10 times both wifi and lan drop, most the time it is just the LAN
a simple reset fixes the problem
the satallite will drop (it goes megenta) - but I can connect to the base wifi (most the time)
*typically I would guess a memory leak of some kind but because it just effects LAN devices I'm not sure
I have unplugged everything and tested the router Lan still drops if I leave one workstation in
Dropping occures after 20+ hrs of run time
typically after I return home so maybe 2+ hours of idle connection
If I leave something like netflix on I haven't noticed a drop
At first I guessed it was because my google home and chromecast(lan) but I have had them unplugged for a good few weeks and the problem still occures. I aslo rewrote all my android phones to pre 8.0
my old asus rt56 has no issues like this (its old and slow needs to be replaced)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Smartthings hub, Playstation 4 and Sony TV. Disconnecting and reconnecting seems to have fixed the problem...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you remove all switches and directly connect each device directly to the router and see if any thing changes?
What is the Mfr and model of the external swtich?
@Brain29wrote:ethernet devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
Wonder if there was some conflic or hang up with between these devices and the router.
Glad you got it working. Let us know if it happens again.
@Guapo_Apowrote:Smartthings hub, Playstation 4 and Sony TV. Disconnecting and reconnecting seems to have fixed the problem...
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38
"I have unplugged "everything" and tested the router Lan still drops if I leave one workstation in"
why is 2.0.1.4 current but 2.1.2.18 previous -- is there something wrong with 2.1.2.18
the logs are pretty unhelpful *they dont show any error or drop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes NG pulled v.18 due to complaints from customers so v.14 is most current.
If it's still dropping connections, I would contact NG support and get more help and information on this, you may have a bad unit and would need to be replaced. Ask about an RMA.
@Brain29wrote:
@FURRYe38"I have unplugged "everything" and tested the router Lan still drops if I leave one workstation in"
- Mark as New
- Bookmark
- Subscribe
- Permalink
ill go back to 1.4 and see if it still happens *cross my fingers
is there a way to turn off auto update without the Telnet hack ? seems kind of stupid to not have setting to pause or delay or wait for updates to be approved
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I would factory reset, load the FW file using IE11 or FF, factory reset all wired to the router with a ethernet cable PC. Set up from scratch.
Hope this helps.
I don't believe so. You'll have to try the telnet work around...
@Brain29wrote:ill go back to 1.4 and see if it still happens *cross my fingers
