Orbi WiFi 7 RBE973
Reply
RBR50 No internet from ethernet ports
bsterling
Tutor
This weekend I lost internet connection for everything connected via ethernet in my main unit.  Wifi still works great.  I do have a switch and it still shows connections, just no internet.  I have tried connecting a laptop straight to ethernet connection on Orbi, and it connects but no internet.  I have tried all the connections.  Router version is V2.7.2.104.  None of my devices show up as "wired" anymore.  Thanks in advace.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 10
Accepted Solutions
Guru
Re: RBR50 No internet from ethernet ports
Seems like a hardware failure at the RBR. Smiley Sad
Message 8 of 10
All Replies
Guru
What wired devices do you have connected?
Message 2 of 10
vajim
Master
you may want to roll your firmware back.
lots of problems being reported with V2.7.2.104.
Message 3 of 10
bsterling
Tutor
Thanks guys- I will try a rollback first and then will do a factory reset.  Very interestingly, the ethernet ports on the satellites work...
Message 4 of 10
vajim
Master
excellent idea
Message 5 of 10
Guru
Try a factory reset first with v104 loaded. Should clear out anything. I would also power OFF the RBR for 30 seconds then back ON.
Message 6 of 10
vajim
Master
already on the way to a roll back....sorry
Message 7 of 10
Guru
Message 8 of 10
bsterling
Tutor
Yes, I agree.  Thanks for all the help
Message 9 of 10
Guru
Hope you can find a replacement RBR.
Good Luck.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2360 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
