Orbi WiFi 7 RBE973
Reply
RBR50 Orbi Guest Password Doesn't Work
wagnermba
Guide
Hi: I set a guest password for my RBR50 Orbi Router -- using Orbi app on iPhone and also from the web admin page.  But, whenever I try to login to it via phone or computer, it says "incorrect password."  I've confirmed I'm using the correct one (that includes a cap letter, three numbers and two punctuation marks).  I changed the Guest WiFi Settings security method from WPA2-Personal to WPA/WOA2-Personal and neither made a difference.  I also rebooted the router via the Orbi app. Any other suggestions?  Thanks!
Message 1 of 4
Accepted Solutions
Guru
Re: RBR50 Orbi Guest Password Doesn't Work
Try removing the special characters from the ssid/password?
Message 2 of 4
All Replies
Guru
Message 2 of 4
wagnermba
Guide
Thank you.  That did the trick!
Message 3 of 4
Guru
Glad it was an easy fix!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1256 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
