Orbi WiFi 7 RBE973
Reply
RBR50 Orbi
Kt812
Follower
RBR50 Orbi
Problem with video download with RBR50! When I connected withRBR50, I can’t access any videos ! Only text will show up. It’s work before ! I am not sure because the firmware update. ! The Armore function, will it affect the internet !
Message 1 of 3
Guru
Re: RBR50 Orbi
Need more info! (sorry, had to add the exclamation mark)
1. What firmware are you on?
2. Are you running Armor and/or disney circle?
3. What video isn't working? Netflix, youtube, etc
4. Is it a specific site or a local streaming?
5. Does it work if you disable armor? Armor can block specific url's
6. Have you tried a reboot?
Message 2 of 3
Guru
Re: RBR50 Orbi
Try a factory reset on the RBR and setup from scratch.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 753 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
