Orbi WiFi 7 RBE973
Reply
RBR50: Playstation gaming on wifi EXTREMELY BAD
wallywizard
Problem: Playstation is lagging very bad, can hardly play.
Orbi RBR50 (firmware v2.5.1.8)
  • channel 2.4Ghz (I tried different channels, 1,6,11 etc..)
  • back haul is on 5Ghz
Residence is a two story 1400sqft condo
ISP = COX
  • download 100+ mbps
  • upload 10+ mbps
Router is on lower level (where the main cox line coming in). My playstation is on the 2nd floor connected to a satellite. My gaming experience (fornite) is very terrible. I tried connecting to the satellite via ethernet and WIFI, both ways resulted in same terrible problem.  Game lags and my ping is about 40.
I am able to go online and browse, netflix, etc no problem. The issue seems to be only when I am trying to game.
I even tried to uncheck daisy chain and other features to see if it helped but it did not. Does anyone know what else I can do?
Thank you
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: RBR50: Playstation gaming on wifi EXTREMELY BAD
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Turn OFF the RBS and connect the console to the RBR via wireless, does gaming still exhibit this when connected to the RBR?
Ethernet wire connected game consoles is preferred.
Please try a factory reset and setup from scratch with the RBR and RBS.
Message 2 of 4
wallywizard
  • For my 2.4ghz I've tried channels 1,6,11
  • ive rebooted/factory reset (brand new orbi)
  • yes many neighbors (condo)
  • PlayStation is wired into satellite. Router is on different floor.
  • cable modem is 8yrs old Cisco .. I don't know the exact model.
Message 3 of 4
Guru
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Turn down the power on the RBR from 100% to 75 or 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Gaming consoles have best performance if directly wired to the RBR.
Please find model# of ISP Modem.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 794 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
