- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
RBR50/RBS50 Firmware 2.5.1.16 Update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50/RBS50 Firmware 2.5.1.16 Update
You could also look at alternative firmware. There are options out there that people really like. I might consider it in the future.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also have not had any issues with v16 FW.
Users should try a factory reset and setup from scratch to see if the problem continues.
There is also newer FW out as well that users can try:
You can try Voxels FW for Orbi:
https://community.netgear.com/t5/Orbi/Voxels-FW-available-for-50-series-Orbi-only-available/m-p/1883...
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-a-la-faq.65224/
You can revert back to stock FW if it doesn't work out for you.
@jeff022889 wrote:Ever since the Firmware 2.5.1.16 Update my WIFI is cutting off every 5 minutes. The outage last only 10-15 seconds which is long enought to destroy connectivity to my many IoT devices. Can someone please give me a work around or solution?
I am considering throwing my $600 Netgear WIFI in the trash and starting over. I work from home and can not tolerate this level of service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Petiel315 wrote:Sir
I have the same issues
support will not help you
management will not help you
i have filed in my local county court a lawsuit against netgear for the amount of money I have paid for this Orbi garbage
it is absolute trash
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why not revert back to the old firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi is working for me.
Others as well:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update working for me. Strange issue is the Satellites no longer can determine the attached devices names. They only show IP and MAC addresses of attached devices, yet the router knows and displays them. The satellites displayed the device names before the update.
Still annoying that attached devices can be sorted when being displayed. Seems a simple programming task to be able to sort the list...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something to contact NG support about and let them know. Seems like they keep fixing this, then it break again after another update or two.
I wonder if v4 or v70 have fix the device naming issue yet.
@yabanjin wrote:Update working for me. Strange issue is the Satellites no longer can determine the attached devices names. They only show IP and MAC addresses of attached devices, yet the router knows and displays them. The satellites displayed the device names before the update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No customer service management
They do care about end users
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Petiel315 wrote:
Netgear management and support is horrendous
I believe you meant to say "They do NOT care about end users". Their customer support is the absolute worst in the industry. I suggest everyone file their complaint with the Better Business Bureau, my complaint is filed with the BBB and is still pending NG's response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Garbage
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried that
Filled with the Californian and Ohio AG office, Netgear would not respond
They really are a bunch of narcistic self centered arrogant obnoxious individuals
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- Next »
