Orbi WiFi 7 RBE973
Reply
RBR50 / RBS50 Firmware Version 2.0.0.76 issues
I upgraded my RBR50/RBS50 systems to firmware v2.0.0.76 and noticed that DHCP requests are no longer being logged and I can no longer connect to the router using my Android cellphone. Anyone else notice any issues with this firmware version?
Message 1 of 19
Re: RBR50 / RBS50 Firmware Version 2.0.0.76 issues
Correction: I can connect using my Android Phone, but only a white page is displayed after login.
Message 2 of 19
Curiously the ability to login into my router from Android phone is working correctlry now, but it still bothers me that dhcp entries are not being logged. Was the fix to dhcp to simply turn off all logging?
Message 3 of 19
Charleem
Guide
Hi, on the update page it says to write down all your settings, does this mean that once it's updated all of the settings will need to be put in again?
Thanks.
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 4 of 19
tagteam
Virtuoso
Yes, but you can backup your configuration settings by going to Advanced>>Administration>>Backup Settings in the browser GUI.
Message 5 of 19
Charleem
Guide
Ah that's great thanks.
I'm still a bit apprehensive about installing beta firmware though.
Message 6 of 19
Stev3D
Luminary
I sorry about asking a question about a question, but my Orbi Tri-band RBR50/RBS50 report that they are "current" at v2.0.0.74 -- even the corresponding Netgear support page says that this is "current."  Is this a beta or are we talking about different models?  Apologies in advance for being a dunce (if that's the case).
Message 7 of 19
Charleem
Guide
Message 8 of 19
Stev3D
Luminary
Thank you, Charleem.  I am happy to try out the beta since I powerd off my RBS50 (satellite) a week after KRACK was announced and there was no replacement firmware in sight.
Message 9 of 19
Charleem
Guide
That's cool let me know how you get on please.
Message 10 of 19
Stev3D
Luminary
Installation went well.  It has been up and running for some 20 minutes.  The computer I'm using now connected to the Satellite (as expected by proximity), but I'm a little surprised that the MCS Index is only 6 given the distance and interceding materials.  However the measured throughput is what I would expect. I've walked through my settings and all seems right.  I can't verify that they've addressed the protocol issue with KRACK, but one has to hope that they did it right.
Message 11 of 19
Stev3D
Luminary
One more question:  How does one learn of these beta releases?  I didn't see anything public about it.
Message 12 of 19
Charleem
Guide
It was just luck, I'd been checking the support page for the Orbi every week and spotted that update.
It'd be handy if they did email but at least they auto update when the version is fully released.
I'm not going to update to the beta until I'm back from holiday mid December, by which time I hope it'll be out of testing.
Message 13 of 19
carbonyle
Are you having the same dl/up speeds? I'm on *74 right now, my upload speed is normal but the dl has been half of what it should be, and I feel it's been since the *74 firmware went out. I might give a shot to *76 and see if it changes anything.
Message 14 of 19
Charleem
Guide
Hi, my home fibre is 300 down 20 up but I get 330 down and 22 up, mainly because they have a 10% margin on the advertised speeds so everyone gets as close to what they're paying for.
Message 15 of 19
I haven't noticed any difference with regard to speed with the *76 release.
Message 16 of 19
A couple of reboots later and all is well, except for the logging issue.
Message 17 of 19
Stev3D
Luminary
For my system, upload and download throughput are just what they should be.
Message 18 of 19
carbonyle
Thanks for the feedback guys!
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 4180 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
